hypre preconditioners
Barry Smith
bsmith at mcs.anl.gov
Tue Jul 14 10:42:58 CDT 2009
First run the three cases with -log_summary (also -ksp_view to see
exact solver options that are being used) and send those files. This
will tell us where the time is being spent; without this information
any comments are pure speculation. (For example, the "copy" time to
hypre format is trivial compared to the time to build a hypre
preconditioner and not the problem).
What you report is not uncommon; the setup and per iteration cost
of the hypre preconditioners will be much larger than the simpler
Jacobi preconditioner.
Barry
On Jul 14, 2009, at 3:36 AM, Klaij, Christiaan wrote:
> I'm solving the steady incompressible Navier-Stokes equations
> (discretized with FV on unstructured grids) using the SIMPLE
> Pressure Correction method. I'm using Picard linearization and solve
> the system for the momentum equations with BICG and for the pressure
> equation with CG. Currently, for parallel runs, I'm using JACOBI as
> a preconditioner. My grids typically have a few million cells and I
> use between 4 and 16 cores (1 to 4 quadcore CPUs on a linux
> cluster). A significant portion of the CPU time goes into solving
> the pressure equation. To reach the relative tolerance I need, CG
> with JACOBI takes about 100 iterations per outer loop for these
> problems.
> In order to reduce CPU time, I've compiled PETSc with support for
> Hypre and I'm looking at BoomerAMG and Euclid to replace JACOBI as a
> preconditioner for the pressure equation. With default settings,
> both BoomerAMG and Euclid greatly reduce the number of iterations:
> with BoomerAMG 1 or 2 iterations are enough, with Euclid about 10.
> However, I do not get any reduction in CPU time. With Euclid, CPU
> time is similar to JACOBI and with BoomerAMG it is approximately
> doubled.
> Is this what one can expect? Are BoomerAMG and Euclid meant for much
> larger problems? I understand Hypre uses a different matrix storage
> format, is CPU time 'lost in translation' between PETSc and Hypre
> for these small problems? Are there maybe any settings I should
> change?
> Chris
> <mime-attachment.jpeg><mime-attachment.jpeg>
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> MARIN
> 2, Haagsteeg
> c.klaij at marin.nl
> P.O. Box 28
> T +31 317 49 39 11
> 6700 AA Wageningen
> F +31 317 49 32 45
> T +31 317 49 33 44
> The Netherlands
> I www.marin.nl
> MARIN webnews: First AMT'09 conference, Nantes, France, September 1-2
> This e-mail may be confidential, privileged and/or protected by
> copyright. If you are not the intended recipient, you should return
> it to the sender immediately and delete your copy from your system.
