hypre preconditioners
Klaij, Christiaan
C.Klaij at marin.nl
Tue Jul 14 03:36:15 CDT 2009
I'm solving the steady incompressible Navier-Stokes equations (discretized with FV on unstructured grids) using the SIMPLE Pressure Correction method. I'm using Picard linearization and solve the system for the momentum equations with BICG and for the pressure equation with CG. Currently, for parallel runs, I'm using JACOBI as a preconditioner. My grids typically have a few million cells and I use between 4 and 16 cores (1 to 4 quadcore CPUs on a linux cluster). A significant portion of the CPU time goes into solving the pressure equation. To reach the relative tolerance I need, CG with JACOBI takes about 100 iterations per outer loop for these problems.
In order to reduce CPU time, I've compiled PETSc with support for Hypre and I'm looking at BoomerAMG and Euclid to replace JACOBI as a preconditioner for the pressure equation. With default settings, both BoomerAMG and Euclid greatly reduce the number of iterations: with BoomerAMG 1 or 2 iterations are enough, with Euclid about 10. However, I do not get any reduction in CPU time. With Euclid, CPU time is similar to JACOBI and with BoomerAMG it is approximately doubled.
Is this what one can expect? Are BoomerAMG and Euclid meant for much larger problems? I understand Hypre uses a different matrix storage format, is CPU time 'lost in translation' between PETSc and Hypre for these small problems? Are there maybe any settings I should change?
Chris
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I http://www.marin.nl/
http://www.marin.nl/web/show/id=46836/contentid=2324 First AMT'09 conference, Nantes, France, September 1-2
This e-mail may be confidential, privileged and/or protected by copyright. If you are not the intended recipient, you should return it to the sender immediately and delete your copy from your system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090714/7ea9abd5/attachment.htm>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090714/7ea9abd5/attachment.jpeg>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090714/7ea9abd5/attachment-0001.jpeg>
