make test
Yixun Liu
enjoywm at cs.wm.edu
Sun Jul 5 13:05:17 CDT 2009
I run it on my computer.
md[/home/scratch/yixun/petsc-3.0.0-p3/src/ksp/ksp/examples/tutorials>make
ex2
mpicc -o ex2.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -g3
-I/home/scratch/yixun/petsc-3.0.0-p3/src/dm/mesh/sieve
-I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
-I/home/scratch/yixun/petsc-3.0.0-p3/include
-I/usr/lib64/mpi/gcc/openmpi/include -I/usr/lib64/mpi/gcc/openmpi/lib64
-D__SDIR__="src/ksp/ksp/examples/tutorials/" ex2.c
mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -g3 -o ex2 ex2.o
-Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
-L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lpetscksp
-lpetscdm -lpetscmat -lpetscvec -lpetsc -lX11 -llapack -lblas
-L/usr/lib64/mpi/gcc/openmpi/lib64
-L/usr/lib64/gcc/x86_64-suse-linux/4.3 -L/usr/lib64 -L/lib64
-L/usr/x86_64-suse-linux/lib -ldl -lmpi -lopen-rte -lopen-pal -lnsl
-lutil -lgcc_s -lpthread -lmpi_f90 -lmpi_f77 -lgfortranbegin -lgfortran
-lm -lm -L/usr/lib64/gcc/x86_64-suse-linux -L/usr/x86_64-suse-linux/bin
-L/lib -lm -lm -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s
-lpthread -ldl
/bin/rm -f ex2.o
md[/home/scratch/yixun/petsc-3.0.0-p3/src/ksp/ksp/examples/tutorials>mpiexec
-n 2 ./ex2
DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined symbol:
dat_registry_add_provider
WARNING: Failed to open "OpenIB-cma"
[DAT_PROVIDER_NOT_FOUND:DAT_NAME_NOT_REGISTERED].
This may be a real error or it may be an invalid entry in the uDAPL
Registry which is contained in the dat.conf file. Contact your local
System Administrator to confirm the availability of the interfaces in
the dat.conf file.
WARNING: Failed to open "OpenIB-cma-1"
the dat.conf file.
DAT: library load failure: /usr/lib64/libdaplscm.so.1: undefined symbol:
WARNING: Failed to open "OpenIB-mthca0-1"
the dat.conf file.
WARNING: Failed to open "OpenIB-mthca0-2"
the dat.conf file.
WARNING: Failed to open "OpenIB-mlx4_0-1"
the dat.conf file.
WARNING: Failed to open "OpenIB-mlx4_0-2"
the dat.conf file.
WARNING: Failed to open "OpenIB-iwarp"
the dat.conf file.
[0,1,0]: uDAPL on host md was unable to find any NICs.
Another transport will be used instead, although this may result in
lower performance.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
[0,1,1]: uDAPL on host md was unable to find any NICs.
lower performance.
Norm of error 0.000411674 iterations 7
Satish Balay wrote:
> Looks like some issue with your MPI. You might want to talk with your
> sysadmin about it.
> Also send us some compile logs - so we know whats hapenning. For eg:
> cd src/ksp/ksp/examples/tutorials/
> make ex2
> mpiexec -n 2 ./ex2 [or however you are supporsed to run MPI binaries on this cluster]
> BTW: If you are currently doing development - don't bother with a
> cluster MPI - and just use --download-mpich=1
> Satish
> On Sun, 5 Jul 2009, Yixun Liu wrote:
>> Hi,
>> After making test, I received a lot of warnings and lib load failures.
>> Running test examples to verify correct installation
>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
>> process
>> See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> lower performance.
>> lid velocity = 0.0016, prandtl # = 1, grashof # = 1
>> Number of Newton iterations = 2
>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
>> processes
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> lower performance.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> lower performance.
>> Possible error running Graphics examples
>> src/snes/examples/tutorials/ex19 1 MPI process
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> lower performance.
>> Error running Fortran example src/snes/examples/tutorials/ex5f with 1
>> MPI process
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> the dat.conf file.
>> lower performance.
>> Number of Newton iterations = 4
>> Completed test examples
>> Thanks.
>> Yixun
