make test
Sun Jul 5 13:17:24 CDT 2009
On Sun, 5 Jul 2009, Yixun Liu wrote:
> I run it on my computer.
> md[/home/scratch/yixun/petsc-3.0.0-p3/src/ksp/ksp/examples/tutorials>make
> ex2
> mpicc -o ex2.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -g3
> -I/home/scratch/yixun/petsc-3.0.0-p3/src/dm/mesh/sieve
> -I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
> -I/home/scratch/yixun/petsc-3.0.0-p3/include
> -I/usr/lib64/mpi/gcc/openmpi/include -I/usr/lib64/mpi/gcc/openmpi/lib64
> -D__SDIR__="src/ksp/ksp/examples/tutorials/" ex2.c
> mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -g3 -o ex2 ex2.o
> -Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
> -L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lpetscksp
> -lpetscdm -lpetscmat -lpetscvec -lpetsc -lX11 -llapack -lblas
> -L/usr/lib64/mpi/gcc/openmpi/lib64
> -L/usr/lib64/gcc/x86_64-suse-linux/4.3 -L/usr/lib64 -L/lib64
> -L/usr/x86_64-suse-linux/lib -ldl -lmpi -lopen-rte -lopen-pal -lnsl
> -lutil -lgcc_s -lpthread -lmpi_f90 -lmpi_f77 -lgfortranbegin -lgfortran
> -lm -lm -L/usr/lib64/gcc/x86_64-suse-linux -L/usr/x86_64-suse-linux/bin
> -L/lib -lm -lm -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s
> -lpthread -ldl
> /bin/rm -f ex2.o
Did you install this OpenMPI - or did someone-else/sysadmin install it for you?
> md[/home/scratch/yixun/petsc-3.0.0-p3/src/ksp/ksp/examples/tutorials>mpiexec
> -n 2 ./ex2
> DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined symbol:
> dat_registry_add_provider
> WARNING: Failed to open "OpenIB-cma"
> [DAT_PROVIDER_NOT_FOUND:DAT_NAME_NOT_REGISTERED].
> This may be a real error or it may be an invalid entry in the uDAPL
> Registry which is contained in the dat.conf file. Contact your local
> System Administrator to confirm the availability of the interfaces in
> the dat.conf file.
Your mpiexec is trying to run on infiniban and failing?
> [0,1,1]: uDAPL on host md was unable to find any NICs.
> Another transport will be used instead, although this may result in
> lower performance.
> Norm of error 0.000411674 iterations 7
And then it attempts 'sockets' - and then successfully runs the PETSc example..
So something is wrong with your mpi usage. I guess - you'll have to
check with your sysadmin - how to correctly use infiniband..
Satish
