VecSetValue
Matthew Knepley
knepley at gmail.com
Sat Feb 28 18:23:24 CST 2009
On Sat, Feb 28, 2009 at 6:19 PM, Yixun Liu <enjoywm at cs.wm.edu> wrote:
> I use VecSetValue in a loop and if I add some codes such as IO before
> the VecSetValue the output of the vector is correct. However if I remove
> the IO the output is wrong. It seems that the values are cached and need
> some time to be set.
1) It is unclear what the wrong behavior is.
2) This is also the a sign that memory might be corrupt somewhere else.
It is not possible to see what is wrong from your description, but I assure
you that nothing is wrong with that method. It is used millions of times
every day. Send a sample code with known output and I will run it.
Matt
> Matthew Knepley wrote:
> > I cannot understand your question.
> > Matt
> > On Fri, Feb 27, 2009 at 6:45 PM, Yixun Liu <enjoywm at cs.wm.edu
> > <mailto:enjoywm at cs.wm.edu>> wrote:
> > Hi,
> > VecCreate(PETSC_COMM_WORLD,&solutionDisplacementVector);
> > VecSetSizes(solutionDisplacementVector,
> > 3*numOfVerticesOfOneProcessor,
> > systemSize); //in this case 3*numOfVerticesOfOneProcessor==systemSize
> > VecSetFromOptions(solutionDisplacementVector);
> > VecDuplicate(solutionDisplacementVector,
> > &weightedDisplacementVector);
> > for(i = 0; i < systemSize; i++)
> > output weightedRealDisplacement[i] to file//with this code the
> > values in
> > weightedDisplacementVector are correct.
> > VecSetValue(weightedDisplacementVector, i,
> > weightedRealDisplacement[i],
> > ADD_VALUES);
> > VecAssemblyBegin(weightedDisplacementVector);
> > VecAssemblyEnd(weightedDisplacementVector);
> > output weightedDisplacementVector to file to see its values
> > For simplicity I only use one processor. As I examine the values in
> > weightedDisplacementVector and I found if I add the output code
> > in the
> > for loop the values in weightedDisplacementVector are correct.
> Without
> > it there is error.
> > Thanks.
> > Yixun
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090228/fad55600/attachment.htm>
