VecSetValue(ignore last one)
Yixun Liu enjoywm at cs.wm.edu
Fri Feb 27 20:00:43 CST 2009
I made a mistake in previous email. Please ignore the last one.
  VecCreate(PETSC_COMM_WORLD,&solutionDisplacementVector);
  VecSetSizes(solutionDisplacementVector, 3*numOfVerticesOfOneProcessor,
systemSize); //in this case 3*numOfVerticesOfOneProcessor==systemSize
  VecSetFromOptions(solutionDisplacementVector);
 VecDuplicate(solutionDisplacementVector, &weightedDisplacementVector);
for(k=0; k<systemSize;k++)
i = func();
output weightedRealDisplacement[i] to file//with this code the values in weightedDisplacementVector are correct.
VecSetValue(weightedDisplacementVector, i, weightedRealDisplacement[i], ADD_VALUES);// in different iteration i maybe same.
VecAssemblyBegin(weightedDisplacementVector);
 VecAssemblyEnd(weightedDisplacementVector);
output weightedDisplacementVector to file to see its values
For simplicity I only use one processor. As I examine the values in
weightedDisplacementVector and I found if  I add the output code in the
for loop the values in weightedDisplacementVector are correct. Without
it there are some errors.
Thanks.
Yixun
