VecSetValue
Yixun Liu enjoywm at cs.wm.edu
Sat Feb 28 18:19:18 CST 2009
I use VecSetValue in a loop and if I add some codes such as IO before
the VecSetValue the output of the vector is correct. However if I remove
the IO the output is wrong. It seems that the values are cached and need
some time to be set.
Matthew Knepley wrote:
> I cannot understand your question.
>   Matt
> On Fri, Feb 27, 2009 at 6:45 PM, Yixun Liu <enjoywm at cs.wm.edu
> <mailto:enjoywm at cs.wm.edu>> wrote:
>     Hi,
>      VecCreate(PETSC_COMM_WORLD,&solutionDisplacementVector);
>      VecSetSizes(solutionDisplacementVector,
>     3*numOfVerticesOfOneProcessor,
>     systemSize); //in this case 3*numOfVerticesOfOneProcessor==systemSize
>      VecSetFromOptions(solutionDisplacementVector);
>      VecDuplicate(solutionDisplacementVector,
>     &weightedDisplacementVector);
>     for(i = 0; i < systemSize; i++)
>     output weightedRealDisplacement[i] to file//with this code the
>     values in
>     weightedDisplacementVector are correct.
>     VecSetValue(weightedDisplacementVector, i,
>     weightedRealDisplacement[i],
>     ADD_VALUES);
>     VecAssemblyBegin(weightedDisplacementVector);
>      VecAssemblyEnd(weightedDisplacementVector);
>     output weightedDisplacementVector to file to see its values
>     For simplicity I only use one processor. As I examine the values in
>     weightedDisplacementVector and I found if  I add the output code
>     in the
>     for loop the values in weightedDisplacementVector are correct. Without
>     it there is error.
>     Thanks.
>     Yixun
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
