VecSetValue
Sat Feb 28 17:18:45 CST 2009
I cannot understand your question.
  Matt
On Fri, Feb 27, 2009 at 6:45 PM, Yixun Liu <enjoywm at cs.wm.edu> wrote:
> Hi,
>  VecCreate(PETSC_COMM_WORLD,&solutionDisplacementVector);
>  VecSetSizes(solutionDisplacementVector, 3*numOfVerticesOfOneProcessor,
> systemSize); //in this case 3*numOfVerticesOfOneProcessor==systemSize
>  VecSetFromOptions(solutionDisplacementVector);
>  VecDuplicate(solutionDisplacementVector, &weightedDisplacementVector);
> for(i = 0; i < systemSize; i++)
> output weightedRealDisplacement[i] to file//with this code the values in
> weightedDisplacementVector are correct.
> VecSetValue(weightedDisplacementVector, i, weightedRealDisplacement[i],
> ADD_VALUES);
> VecAssemblyBegin(weightedDisplacementVector);
>  VecAssemblyEnd(weightedDisplacementVector);
> output weightedDisplacementVector to file to see its values
> For simplicity I only use one processor. As I examine the values in
> weightedDisplacementVector and I found if  I add the output code in the
> for loop the values in weightedDisplacementVector are correct. Without
> it there is error.
> Thanks.
> Yixun
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090228/22fb39da/attachment.htm>
