cannot config ParMetis
Matthew Knepley
knepley at gmail.com
Sun Feb 22 18:31:08 CST 2009
On Sun, Feb 22, 2009 at 6:17 PM, <enjoywm at cs.wm.edu> wrote:
> > Try replacing --with-parmetis-dir= ... with the option
> > '--download-parmetis'
> > Hong
> > On Sun, 22 Feb 2009, enjoywm at cs.wm.edu wrote:
> >> Hi,
> >> I have installed ParMetis and use the following commands,
> >> /petsc-3.0.0-p3>./config/configure.py
> >> --with-parmetis-dir=/home/scratch/ParMetis-3.1.1
> >> The error is
> >> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> >> details):
> >> --with-parmetis-dir=/home/scratch/yixun/ParMetis-3.1.1 did not work
> >> Thanks.
> I tried it and after make all I can find libparmetis.a and libmetis.a in
> petsc-3.0.0-p3/linux-gnu-c-debug/lib .
> However when I make test,computer stopped here and no any response.
1) With any configuration question, Always always always send configure.log
and make_*.log. Without them, we have no idea what you did.
2) Since that is large, we recommend you use petsc-maint at mcs.anl.govinstead.
3) My guess is that you have an MPI run configuration problem. Can you run
any examples?
cd src/ksp/ksp/examples/tutorials
make ex2
./ex2
$PETSC_DIR/$PETSC_ARCH/bin/mpiexec -n 2 ./ex2
Matt
> Thanks.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090222/21225f5b/attachment.htm>
