cannot config ParMetis
enjoywm at cs.wm.edu enjoywm at cs.wm.edu
Sun Feb 22 18:17:31 CST 2009
> Try replacing --with-parmetis-dir= ... with the option
> '--download-parmetis'
> Hong
> On Sun, 22 Feb 2009, enjoywm at cs.wm.edu wrote:
>> Hi,
>> I have installed ParMetis and use the following commands,
>> /petsc-3.0.0-p3>./config/configure.py
>> --with-parmetis-dir=/home/scratch/ParMetis-3.1.1
>> The error is
>> UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>> details):
>> --with-parmetis-dir=/home/scratch/yixun/ParMetis-3.1.1 did not work
>> Thanks.
I tried it and after make all I can find libparmetis.a and libmetis.a in
petsc-3.0.0-p3/linux-gnu-c-debug/lib .
However when I make test,computer stopped here and no any response.
Thanks.
