cannot config ParMetis
enjoywm at cs.wm.edu enjoywm at cs.wm.edu
Mon Feb 23 08:01:41 CST 2009
> On Sun, Feb 22, 2009 at 6:17 PM, <enjoywm at cs.wm.edu> wrote:
>> > Try replacing --with-parmetis-dir= ... with the option
>> > '--download-parmetis'
>> > Hong
>> > On Sun, 22 Feb 2009, enjoywm at cs.wm.edu wrote:
>> >> Hi,
>> >> I have installed ParMetis and use the following commands,
>> >> /petsc-3.0.0-p3>./config/configure.py
>> >> --with-parmetis-dir=/home/scratch/ParMetis-3.1.1
>> >> The error is
>> >> UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>> >> details):
>> >> --with-parmetis-dir=/home/scratch/yixun/ParMetis-3.1.1 did not work
>> >> Thanks.
>> I tried it and after make all I can find libparmetis.a and libmetis.a in
>> petsc-3.0.0-p3/linux-gnu-c-debug/lib .
>> However when I make test,computer stopped here and no any response.
> 1) With any configuration question, Always always always send
> configure.log
> and make_*.log. Without them, we have no idea what you did.
> 2) Since that is large, we recommend you use
> petsc-maint at mcs.anl.govinstead.
> 3) My guess is that you have an MPI run configuration problem. Can you run
> any examples?
>   cd src/ksp/ksp/examples/tutorials
>   make ex2
>   ./ex2
>   $PETSC_DIR/$PETSC_ARCH/bin/mpiexec -n 2 ./ex2
>    Matt
>> Thanks.
> experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Thanks.
After restart it works now.
