petsc 3.0.0 test woes
Barry Smith
bsmith at mcs.anl.gov
Tue Feb 17 09:27:55 CST 2009
Please send configure.log and make.log to petsc-maint at mcs.anl.gov
For some reason the shared/dynamic libraries are giving you a problem.
If you don't need them just run config/configure.py
without --with-dynamic=1 and --with-shared=1
The changes from previous release are listed at http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/300.html
Look at the bullet config/configure.py for changes in directory
structure.
Barry
On Feb 17, 2009, at 9:06 AM, Toby D. Young wrote:
> Hi,
> I am trying to migrate to petsc-2.0.0-p3 on an amd64 linux box. I have
> encountered two (unrealted?) problems.
> ** install problem 1
> After exporting PETSC_DIR and PETSC_ARCH
> I use:
> $ ./config/configure.py --with-blas-lib=libblas.so
> --with-lapack-lib=liblapack.so --with-dynamic=1 --with-shared=1
> --with-mpi=0
> and then:
> $make all
> ...and all looks ok libraries are build. Then
> $make test
> complains thus:
> Running test examples to verify correct installation
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
> MPI process See
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> ././ex19:
> symbol lookup error: ././ex19: undefined symbol: petsc_tmp_flops
> Possible error running Graphics examples
> src/snes/examples/tutorials/ex19 1 MPI process See
> ././ex19:
> symbol lookup error: ././ex19: undefined symbol: petsc_tmp_flops Error
> running Fortran example src/snes/examples/tutorials/ex5f with 1 MPI
> process See
> ././ex5f:
> symbol lookup error: ././ex5f: undefined symbol: dmgetlocalvector_
> Completed test examples
> I am unsure how to track down this error, or what it is I am doing
> wrong. This procedure works for sure for petsc-2.3.3-p6 Any ideas
> please?
> ** install problem 2
> Sadly (for me), it seems that the petsc directory structure has
> changed
> from 2.3.3-p6; this is bringing development of other packages (deal.ii
> and slepc) to a screaming halt. So I'll try and fix this without
> complaining :-)
> I have noticed this change:
> petsc-2.3.3-p6/lib --> petsc-3.0.0-p6/$(PETSC_ARCH)/lib
> Can someone kindly point me of other directory structure changes I
> should look out for, or is there a page on the PETSc website which
> documents these changes I can look at.
> Many thanks.
> Best,
> Toby
> Toby D. Young
> Adiunkt (Assistant Professor)
> Philosopher-Physicist
> Department of Computational Science
> Institute of Fundamental Technological Research
> Polish Academy of Sciences
> Room 206, ul. Swietokrzyska 21
> 00-049 Warszawa, Polska
> +48 22 826 12 81 ext. 184
> http://rav.ippt.gov.pl/~tyoung
