config-options
Andreas Grassl
Andreas.Grassl at student.uibk.ac.at
Mon Feb 16 16:20:37 CST 2009
>>>> Hi,
>>>> I played around with some configure options and adapted the python
>>>> scripts from $PETSC_DIR/config/examples, but I didn't find an option to
>>>> save the current standard options to such a script-file.
>>> Not sure I understand the question.
>>> When you run configure with any set of options - and the run is
>>> successful - you get a $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>>> file - with all these options listed in it.
>> Ok, I start from a script like this and wanted to have the default options,
>> which were not set explicitly to appear in a script as well.
> Why?
To have an overview of the settings and to get the full control over the
default-options, but maybe I'm thinking too paranoid and I don't have to change
any default-options.
cheers
ando
\ / ASCII Ribbon
X against HTML email
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090216/147e02dc/attachment.pgp>
