config-options
Satish Balay
balay at mcs.anl.gov
Mon Feb 16 16:14:09 CST 2009
On Mon, 16 Feb 2009, Andreas Grassl wrote:
> >> Hi,
> >> I played around with some configure options and adapted the python
> >> scripts from $PETSC_DIR/config/examples, but I didn't find an option to
> >> save the current standard options to such a script-file.
> > Not sure I understand the question.
> > When you run configure with any set of options - and the run is
> > successful - you get a $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> > file - with all these options listed in it.
> Ok, I start from a script like this and wanted to have the default options,
> which were not set explicitly to appear in a script as well.
Why?
> >> Is there a possibility to get all the configure options?
> > Hmm - you can run configure with '--help' option - and it will list
> > all the options configure accepts.
> do I have to parse them out manually?
I guess so.. We don't have a way to format and dump this.
Satish
