config-options
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Mon Feb 16 16:08:32 CST 2009
Satish Balay schrieb:
> On Mon, 16 Feb 2009, Andreas Grassl wrote:
>> Hi,
>> I played around with some configure options and adapted the python
>> scripts from $PETSC_DIR/config/examples, but I didn't find an option to
>> save the current standard options to such a script-file.
> Not sure I understand the question.
> When you run configure with any set of options - and the run is
> successful - you get a $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> file - with all these options listed in it.
Ok, I start from a script like this and wanted to have the default options,
which were not set explicitly to appear in a script as well.
>> Is there a possibility to get all the configure options?
> Hmm - you can run configure with '--help' option - and it will list
> all the options configure accepts.
do I have to parse them out manually?
cheers
ando
 \ /      ASCII Ribbon
  X    against HTML email
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090216/680cfe76/attachment.pgp>
