inverting independent, small dense matrices
Shao-Ching Huang
schuang at ats.ucla.edu
Fri Feb 13 17:29:08 CST 2009
Barry:
How do I determine the "shift" value, to be passed into
Kernel_A_gets_inverse_A_4(MatScalar *a,PetscReal shift)
I know that my 4x4 matrices are non-singular for sure.
Thanks.
Shao-Ching
Barry Smith wrote:
> On Feb 13, 2009, at 3:01 PM, Shao-Ching Huang wrote:
>> Hi
>> I need to invert a bunch of independent, dense 4x4 matrices on each
>> MPI process. (This is separate from the main computation, a parallel
>> Ax=b solve.) I am thinking of using LAPACK's DGESV to invert these 4x4
>> matrices.
> You would not want to use LAPACK's solvers for such tiny matrices.
> LAPACK is optimized
> for large dense matrices; the overhead is high for small matrices so
> that actual performance will
> be very slow calling LAPACK.
>> In my code, is it necessary to call LAPACK directly? Or does PETSc
>> already have a convenient interface to LAPACK?
> For PETSc's own internal use we have written custom inverters for
> small matrices (these are used by
> the factorization routines for BAIJ matrices). They are called
> Kernel_A_gets_inverse_A_* where * is the block size.
> The prototypes for the functions are in src/inline/ilu.h and the actual
> source code in files in src/mat/impls/baij/seq/dgef*.c
> Barry
>> The size 4x4 may be increased to 8x8 or so later, so I am not trying
>> to use the closed-form inversion formula.
>> Thanks,
>> Shao-Ching
