inverting independent, small dense matrices
Matthew Knepley
knepley at gmail.com
Fri Feb 13 17:35:17 CST 2009
On Fri, Feb 13, 2009 at 5:29 PM, Shao-Ching Huang <schuang at ats.ucla.edu>wrote:
> Barry:
> How do I determine the "shift" value, to be passed into
> Kernel_A_gets_inverse_A_4(MatScalar *a,PetscReal shift)
> I know that my 4x4 matrices are non-singular for sure.
Then you use 0.0;
Matt
> Thanks.
> Shao-Ching
> Barry Smith wrote:
>> On Feb 13, 2009, at 3:01 PM, Shao-Ching Huang wrote:
>> Hi
>>> I need to invert a bunch of independent, dense 4x4 matrices on each
>>> MPI process. (This is separate from the main computation, a parallel
>>> Ax=b solve.) I am thinking of using LAPACK's DGESV to invert these 4x4
>>> matrices.
>> You would not want to use LAPACK's solvers for such tiny matrices.
>> LAPACK is optimized
>> for large dense matrices; the overhead is high for small matrices so that
>> actual performance will
>> be very slow calling LAPACK.
>> In my code, is it necessary to call LAPACK directly? Or does PETSc
>>> already have a convenient interface to LAPACK?
>>> For PETSc's own internal use we have written custom inverters for
>> small matrices (these are used by
>> the factorization routines for BAIJ matrices). They are called
>> Kernel_A_gets_inverse_A_* where * is the block size.
>> The prototypes for the functions are in src/inline/ilu.h and the actual
>> source code in files in src/mat/impls/baij/seq/dgef*.c
>> Barry
>> The size 4x4 may be increased to 8x8 or so later, so I am not trying
>>> to use the closed-form inversion formula.
>>> Thanks,
>>> Shao-Ching
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090213/7a0eeb68/attachment.htm>
