inverting independent, small dense matrices
Shao-Ching Huang schuang at ats.ucla.edu
Fri Feb 13 15:49:50 CST 2009
>      For PETSc's own internal use we have written custom inverters for
> small matrices (these are used by
> the factorization routines for BAIJ matrices).  They are called
> Kernel_A_gets_inverse_A_* where * is the block size.
> The prototypes for the functions are in src/inline/ilu.h and the actual
> source code in files in src/mat/impls/baij/seq/dgef*.c
Beautiful! I will try it out.
Thank you.
Shao-Ching
