inverting independent, small dense matrices
Fri Feb 13 15:17:04 CST 2009
On Feb 13, 2009, at 3:01 PM, Shao-Ching Huang wrote:
> Hi
> I need to invert a bunch of independent, dense 4x4 matrices on each
> MPI process. (This is separate from the main computation, a parallel
> Ax=b solve.) I am thinking of using LAPACK's DGESV to invert these 4x4
> matrices.
      You would not want to use LAPACK's solvers for such tiny
matrices. LAPACK is optimized
for large dense matrices; the overhead is high for small matrices so
that actual performance will
be very slow calling LAPACK.
> In my code, is it necessary to call LAPACK directly? Or does PETSc
> already have a convenient interface to LAPACK?
      For PETSc's own internal use we have written custom inverters
for small matrices (these are used by
the factorization routines for BAIJ matrices).  They are called
Kernel_A_gets_inverse_A_* where * is the block size.
The prototypes for the functions are in src/inline/ilu.h and the
actual source code in files in src/mat/impls/baij/seq/dgef*.c
    Barry
> The size 4x4 may be increased to 8x8 or so later, so I am not trying
> to use the closed-form inversion formula.
> Thanks,
> Shao-Ching
