installation problems in mac machine
Dominik Szczerba
dominik at itis.ethz.ch
Mon Dec 21 15:20:05 CST 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
With sudo you gain administrative rights (still depends on the actual
sudoers config) - in principle you can harm your system by mistake (sudo
rm -fr /usr/lib/* ...). That is why it is normally not allowed on large
multiuser systems. It should be possible to use any non-system software
without it.
Dominik
Matthew Knepley wrote:
> On Mon, Dec 21, 2009 at 3:13 PM, Dominik Szczerba <dominik at itis.ethz.ch
> <mailto:dominik at itis.ethz.ch>> wrote:
> Why use sudo in the first place?
> I am not a mac user, but normally on unix sudo is the last thing you
> want to use during everyday work (provided that you are at all allowed
> to use it).
>> Not sure why you would think that. In fact, sudo is the safe way to do
>> things
>> and recommended for everyday usage.
>> Matt
> Dominik
> Satish Balay wrote:
>> Perhaps 'sudo' is not proegating PETSC_DIR,PETSC_ARCH variables
>> properly?
>> Try 'sudo /bin/bash' and do the whole install in that shell.
>> BTW: you have a typo with PETSC_ARCH further down.. And we recommend
>> using COPTFLAGS, FOPTFLAGS --with-debugging=0 for optimziation builds.
>> Satish
>> On Mon, 21 Dec 2009, hxie at umn.edu <mailto:hxie at umn.edu> wrote:
>>> Hi,
>>> My operation system is Mac OS X 10.6.2. I unzip the petsc under
>>> /usr/local/petsc-3.0.0-p10.
>>> I use the following to configure petsc.
>>> sudo ./config/configure.py --CFLAGS=-O3 --FFLAGS=-O3
>>> --with-mpi-dir=/usr/local/mpich2-1.2.1 --with-fortran --with-shared=0
>>> --with-fc=gfortran
>>> And I run the following commands:
>>> export PETS_ARCH=darwin10.2.0-c-debug;
>>> PETSC_DIR=/usr/local/petsc-3.0.0-p10; export PETSC_DIR
>>> When I run " sudo make all", it gives some errors:
>>> makefile:15: /conf/base: No such file or directory
>>> makefile:16: /conf/test: No such file or directory
>>> make: *** No rule to make target `/conf/test'. Stop.
>>> It seems it cannot find the PETSC_DIR. (I use x11. "echo $SHELL" gets
>>> "/bin/bash")
>>> Do I need to add "PETSC_DIR = /usr/local/petsc-3.0.0-p10" in the
> makefile
>>> file? Thanks.
>>> Bests,
>>> Hui
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAksv5oUACgkQ/EBMh9bUuzLRRgCgouQAgRohpINl9jKpSk00V3LQ
gq4AoM5hM6RilOkTp1wyIBHIxQSLlAOv
=yY0a
-----END PGP SIGNATURE-----
