installation problems in mac machine
Mon Dec 21 15:23:25 CST 2009
On Mon, Dec 21, 2009 at 3:20 PM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> With sudo you gain administrative rights (still depends on the actual
> sudoers config) - in principle you can harm your system by mistake (sudo
>  rm -fr /usr/lib/* ...). That is why it is normally not allowed on large
> multiuser systems. It should be possible to use any non-system software
> without it.
Installation is almost always done with root permission. If you want to be
pendatic,
you can create other users for specific tasks, like the webserver, but you
STILL
sudo to that user.
   Matt
> Dominik
> Matthew Knepley wrote:
> > On Mon, Dec 21, 2009 at 3:13 PM, Dominik Szczerba <dominik at itis.ethz.ch
> > <mailto:dominik at itis.ethz.ch>> wrote:
> > Why use sudo in the first place?
> > I am not a mac user, but normally on unix sudo is the last thing you
> > want to use during everyday work (provided that you are at all allowed
> > to use it).
> >> Not sure why you would think that. In fact, sudo is the safe way to do
> >> things
> >> and recommended for everyday usage.
> >>   Matt
> > Dominik
> > Satish Balay wrote:
> >> Perhaps 'sudo' is not proegating PETSC_DIR,PETSC_ARCH variables
> >> properly?
> >> Try 'sudo /bin/bash' and do the whole install in that shell.
> >> BTW: you have a typo with PETSC_ARCH further down..  And we recommend
> >> using COPTFLAGS, FOPTFLAGS --with-debugging=0 for optimziation builds.
> >> Satish
> >> On Mon, 21 Dec 2009, hxie at umn.edu <mailto:hxie at umn.edu> wrote:
> >>> Hi,
> >>> My operation system is Mac OS X 10.6.2. I unzip the petsc under
> >>> /usr/local/petsc-3.0.0-p10.
> >>> I use the following to configure petsc.
> >>> sudo ./config/configure.py --CFLAGS=-O3 --FFLAGS=-O3
> >>> --with-mpi-dir=/usr/local/mpich2-1.2.1 --with-fortran --with-shared=0
> >>> --with-fc=gfortran
> >>> And I run the following commands:
> >>> export PETS_ARCH=darwin10.2.0-c-debug;
> >>> PETSC_DIR=/usr/local/petsc-3.0.0-p10; export PETSC_DIR
> >>> When I run " sudo make all", it gives some errors:
> >>> makefile:15: /conf/base: No such file or directory
> >>> makefile:16: /conf/test: No such file or directory
> >>> make: *** No rule to make target `/conf/test'.  Stop.
> >>> It seems it cannot find the PETSC_DIR. (I use x11. "echo $SHELL" gets
> >>> "/bin/bash")
> >>> Do I need to add "PETSC_DIR = /usr/local/petsc-3.0.0-p10" in the
> > makefile
> >>> file? Thanks.
> >>> Bests,
> >>> Hui
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iEYEARECAAYFAksv5oUACgkQ/EBMh9bUuzLRRgCgouQAgRohpINl9jKpSk00V3LQ
> gq4AoM5hM6RilOkTp1wyIBHIxQSLlAOv
> =yY0a
> -----END PGP SIGNATURE-----
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091221/85f3b7d1/attachment-0001.htm>
