KSP Tolerances
Matthew Knepley
knepley at gmail.com
Mon Dec 14 09:47:00 CST 2009
No.
On Mon, Dec 14, 2009 at 9:40 AM, Jarunan Panyasantisuk <jarunan at ascomp.ch>wrote:
> Thank you. I see it.
> I also see in the output file that sometimes the initial residual
> ||r_0|| = ||b|| is simply rnorm ||r|| at iteration 0. Does it change
> the reference during the computation?
> Jarunan
> Matthew Knepley wrote:
> > You can see in the info output what is happening. The test is
> > rnorm >= ksp->divtol*ksp->rnorm0
> > Here ||r_0|| = ||b|| = 0.00331536 and ||r|| = 513.979, and thus it
> results
> > in divergence. It appears that ILU(0) is very bad for this problem.
> > Matt
> > On Mon, Dec 14, 2009 at 9:07 AM, <jarunan at ascomp.ch
> > <mailto:jarunan at ascomp.ch>> wrote:
> > Hi,
> > Thank you for your advice. With this mail I attach the output file
> > run.log.
> > My grid is 2-level grid. The coarse grid is computed first then
> > the fine grid. The problem occur in the fine grid. You can see at
> > lines 3098, 4552 and 6127 where it is diverged.
> > Regards,
> > Jarunan
> > Quoting Matthew Knepley <knepley at gmail.com
> > <mailto:knepley at gmail.com>>:
> > Run with -ksp_view -ksp_monitor -info and send us all the output.
> > Matt
> > On Mon, Dec 14, 2009 at 8:36 AM, <jarunan at ascomp.ch
> > Dear Petsc Team,
> > There is something not clear for me about divergence
> > tolerance. Firstly, my
> > computation diverges with the reason of dtol (-4), which
> > was set by default
> > (10000). When I increased dtol to 1.0e+8, it became
> > converged. However, the
> > relative residual where it was diverged is less than the
> > default dtol. I
> > would like to know, how it is exactly calculated.
> > ----------I describe my problem more in detail
> > here.-------------------
> > As I set the tolerances for the solver as below, my
> > problem diverges with
> > converged reason -4 (from divergence tolerance)
> > call KSPSetTolerances(ksp,1.0e-06,1.0e-20,
> > PETSC_DEFAULT_DOUBLE_PRECISION,10000,ierr)
> > I monitor the residual. it printed the information below
> > and quit the
> > computation.(I delete the true residual norm and Ax/Ae.
> > Please tell me if
> > you need them.)
> > 0 KSP preconditioned resid norm 5.139790011051e+02
> > With -ksp_view, it shows that default value of dtol is
> > 10000. I increased
> > dtol to 1.0e+8, then the solver solved the problem. With
> > -ksp_monitor_true_residual, the first 5 iterations read:
> > 1 KSP preconditioned resid norm 1.840751662590e+01
> > 2 KSP preconditioned resid norm 3.653339750400e+00
> > 3 KSP preconditioned resid norm 2.538794826933e+00
> > 4 KSP preconditioned resid norm 2.299844715275e-01
> > Here, from iteration 0 to iteration 1,the relative
> > residual is 0.03580,
> > much less than 1.0e+4 the default dtol value. So, why was
> > it diverged at the
> > first time?
> > Regards,
> > Jarunan
> > Development Engineer
> > ASCOMP GmbH, Technoparkstr. 1
> > CH-8005 Zurich, Switzerland
> > Phone : +41 44 445 4072
> > Fax : +41 44 445 4075
> > E-mail: jarunan at ascomp.ch <mailto:jarunan at ascomp.ch>
> > www.ascomp.ch <http://www.ascomp.ch>
> > What most experimenters take for granted before they begin
> > their experiments
> > is infinitely more interesting than any results to which their
> > experiments
> > lead.
> > -- Norbert Wiener
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> www.ascomp.ch
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091214/f0f119e8/attachment.htm>
