KSP Tolerances
Jarunan Panyasantisuk
jarunan at ascomp.ch
Mon Dec 14 09:40:06 CST 2009
Thank you. I see it.
I also see in the output file that sometimes the initial residual
||r_0|| = ||b|| is simply rnorm ||r|| at iteration 0. Does it change
the reference during the computation?
Jarunan
Matthew Knepley wrote:
> You can see in the info output what is happening. The test is
> rnorm >= ksp->divtol*ksp->rnorm0
> Here ||r_0|| = ||b|| = 0.00331536 and ||r|| = 513.979, and thus it results
> in divergence. It appears that ILU(0) is very bad for this problem.
> Matt
> On Mon, Dec 14, 2009 at 9:07 AM, <jarunan at ascomp.ch
> <mailto:jarunan at ascomp.ch>> wrote:
> Hi,
> Thank you for your advice. With this mail I attach the output file
> run.log.
> My grid is 2-level grid. The coarse grid is computed first then
> the fine grid. The problem occur in the fine grid. You can see at
> lines 3098, 4552 and 6127 where it is diverged.
> Regards,
> Jarunan
> Quoting Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>>:
> Run with -ksp_view -ksp_monitor -info and send us all the output.
> Matt
> On Mon, Dec 14, 2009 at 8:36 AM, <jarunan at ascomp.ch
> Dear Petsc Team,
> There is something not clear for me about divergence
> tolerance. Firstly, my
> computation diverges with the reason of dtol (-4), which
> was set by default
> (10000). When I increased dtol to 1.0e+8, it became
> converged. However, the
> relative residual where it was diverged is less than the
> default dtol. I
> would like to know, how it is exactly calculated.
> ----------I describe my problem more in detail
> here.-------------------
> As I set the tolerances for the solver as below, my
> problem diverges with
> converged reason -4 (from divergence tolerance)
> call KSPSetTolerances(ksp,1.0e-06,1.0e-20,
> PETSC_DEFAULT_DOUBLE_PRECISION,10000,ierr)
> I monitor the residual. it printed the information below
> and quit the
> computation.(I delete the true residual norm and Ax/Ae.
> Please tell me if
> you need them.)
> 0 KSP preconditioned resid norm 5.139790011051e+02
> With -ksp_view, it shows that default value of dtol is
> 10000. I increased
> dtol to 1.0e+8, then the solver solved the problem. With
> -ksp_monitor_true_residual, the first 5 iterations read:
> 1 KSP preconditioned resid norm 1.840751662590e+01
> 2 KSP preconditioned resid norm 3.653339750400e+00
> 3 KSP preconditioned resid norm 2.538794826933e+00
> 4 KSP preconditioned resid norm 2.299844715275e-01
> Here, from iteration 0 to iteration 1,the relative
> residual is 0.03580,
> much less than 1.0e+4 the default dtol value. So, why was
> it diverged at the
> first time?
> Regards,
> Jarunan
> Development Engineer
> ASCOMP GmbH, Technoparkstr. 1
> CH-8005 Zurich, Switzerland
> Phone : +41 44 445 4072
> Fax : +41 44 445 4075
> E-mail: jarunan at ascomp.ch <mailto:jarunan at ascomp.ch>
> www.ascomp.ch <http://www.ascomp.ch>
> What most experimenters take for granted before they begin
> their experiments
> is infinitely more interesting than any results to which their
> experiments
> lead.
> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
www.ascomp.ch
