ksp ex29.c B.C.s and Forcing terms.
Ryan Yan
vyan2000 at gmail.com
Fri Dec 11 15:40:38 CST 2009
Hi All,
I am tring to understand the example in ksp tutorials ex29.c
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/src/ksp/ksp/examples/tutorials/ex29.c.html
For the forcing terms of codes,
array[j][i] =
PetscExpScalar(-((PetscReal)i*Hx)*((PetscReal)i*Hx)/user->nu)*PetscExpScalar(-((PetscReal)j*Hy)*((PetscReal)j*Hy)/user->nu)*Hx*Hy;
if ignoring the scaling, then it is actually calculating a forcing function:
f = e^{-( x)^2/\nu} e^{-( y)^2/\nu}, which is different with the one given
in the comments of the code. Or did I miss somthing here?
For the Dirichlet B.C.s, I did not understand the coefficients
**<http://www.physicsforums.com/showthread.php?t=51412>given
below. Isn't correct to set the v[0]=Hx*Hy here?
if (i==0 || j==0 || i==mx-1 || j==my-1) {
if (user->bcType == DIRICHLET) {
v[0] = 2.0*rho*(HxdHy + HydHx);
Also, for Nueman B.C.s, are we solving for du/dx+du/dy=0?
Sorry for so many detail questions, and thank you very much for any
suggestions.
Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091211/a097a61a/attachment.htm>
