Petsc configure error
irfan.khan at gatech.edu irfan.khan at gatech.edu
Thu Dec 3 13:00:34 CST 2009
Hello Petsc Team
Have there been any more developments on using TAU with PETSc? I have tried to use tau_cc.sh to compile a petsc code. I have attached the error message with this email. Is is necessary to compile MPICH, PETSc and TAU with fortran support?
Thank you
Irfan
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Wednesday, June 24, 2009 5:52:36 PM GMT -05:00 US/Canada Eastern
Subject: Re: Petsc configure error
TAU isn't tested with petsc in the past few years. So thing could be
broken. I'll have to check on this.
One comment though.. If you have tau built with mpi - you should use
that mpi & wrappers with tau and not use --download-mpich. [but this
is also likely broken]
Satish
On Wed, 24 Jun 2009, Ryan Yan wrote:
> Hi all,
> I got configuration errors, when I trying to built PETSC with Tau.
> Basically, I followed the instruction on the installation webpage of PETSc.
> In the attached file, please find the configure log.
> I do built TAU and PDT seperately, and TAU with mpi and PDT.
> If any more information is needed, please let me know.
> Thanks,
> Yan
PhD Candidate
G.W. Woodruff School of Mechanical Engineering
Georgia Institute of Technology
Atlanta, GA (30332)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091203/930c165b/attachment.obj>
