Multiple communicators
Thu Dec 3 13:12:25 CST 2009
On Dec 3, 2009, at 12:59 PM, irfan.khan at gatech.edu wrote:
> Thank you for the response Barry. You are right, the command line
> options do work.
     Good.
     I'm sorry that we don't have a good method of handling the
1) printing of unused options and
2) printing of global log summaries
when PETSc is only used on a subset of communicators.
This processing is done over PETSC_COMM_WORLD and I cannot wrap my
head around any way of properly handling these types of things cleanly
and transparently when using subcommunicators.
    Barry
> From: "Barry Smith" <bsmith at mcs.anl.gov>
> To: "PETSc users list" <petsc-users at mcs.anl.gov>
> Sent: Tuesday, November 24, 2009 11:50:02 PM GMT -05:00 US/Canada
> Eastern
> Subject: Re: Multiple communicators
> On Nov 24, 2009, at 7:13 PM, irfan.khan at gatech.edu wrote:
>> I use seperete communicators for fluid and solid ranks in a fluid-
>> structure interaction code. I use PETSc tools (KSP) to solve for the
>> solid phase (FEA) which is carried out under a different
>> communicator (FEA_Comm).
>> Unless I am doing something wrong, I have found that the command
>> line options: -ksp_type; -mat_partitioning_type, don't work if there
>> are 2 communicators.
>    Are you sure that they don't work? Or is it just printing the
> message?
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-ksp_type value: cg
> Option left: name:-mat_partitioning_type value: parmetis
>    Any option that is not accessed on PROCESS ZERO will be listed
> here as unused, even if it may be used on some process.  I suppose we
> could/should fix this by adding some complicated communication that
> determines just the options that are never used. I never liked this
> warning, only added it after pressure from people who couldn't type.
>> But for single communicator they work. Please see the attached files
>> containing output of -log_summary for 2 different codes (scroll down
>> to the end). One with single communicator and the other with two
>> communicators. Both the output have been generated with the same
>> PETSc compilation.
>> Futher -log_summary results are not able to detect all the events
>> that have been registered if they are not in the WORLD communicator.
>    Is your concern here that it does not print the name of the event,
> it leaves the name blank? If so this is likely the type of problem as
> the print of options; we don't have a mechanism to get them to process
> 0 to print.
>    In summary, yes these are some weaknesses of PETSc. If you switch
> the two communicators you create and use the one that has process 0 of
> MPI_COMM_WORLD for the PETSc stuff then it will look nicer and hide
> these two problems.
>    Barry
>> Thank you
>> Irfan
>> From: "Matthew Knepley" <knepley at gmail.com>
>> Sent: Tuesday, November 24, 2009 8:03:00 PM GMT -05:00 US/Canada
>> Eastern
>> On Tue, Nov 24, 2009 at 6:59 PM, <irfan.khan at gatech.edu> wrote:
>> Hello
>> Does the procedure for providing command line options and to obtain
>> profiling data through -log_summary change if there are multiple MPI
>> communicators in a petsc code?
>> There is always WORLD, so it should be fine unless I misunderstand
>> your question.
>>  Matt
>> If so, can somebody point me to information, references on how to
>> provide command line options if there are multiple communicators?
>> Thank you
>> Irfan
>> PhD Candidate
>> G.W. Woodruff School of Mechanical Engineering
>> Georgia Institute of Technology
>> Atlanta, GA (30332)
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
>> PhD Candidate
>> Atlanta, GA (30332)
>> <1communicator.out><2communicators.out>
> PhD Candidate
> Atlanta, GA (30332)
