make test errors
Matthew Knepley
knepley at gmail.com
Tue Aug 4 15:54:02 CDT 2009
On Tue, Aug 4, 2009 at 3:51 PM, Yixun Liu <enjoywm at cs.wm.edu> wrote:
> Hi,
> I encounter the error as I run make test,
> >make test
> Running test examples to verify correct installation
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
> process
> See
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined symbol:
> dat_registry_add_provider
This looks like a bizarre failure with your OpenMPI compiler wrappers. Do
they work
at all?
Matt
> I list the output of configure. Hope it helpful for diagnosis.
> > ./config/configure.py --download-parmetis
> TESTING: alternateConfigureLibrary from
> PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:69)
> Compilers:
> C Compiler: mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -g3
> Fortran Compiler: mpif90 -Wall -Wno-unused-variable -g
> Linkers:
> Static linker: /usr/bin/ar cr
> PETSc:
> ** Before running "make" your PETSC_ARCH must be specified with:
> ** ** setenv PETSC_ARCH linux-gnu-c-debug (csh/tcsh)
> ** ** PETSC_ARCH=linux-gnu-c-debug; export PETSC_ARCH (sh/bash)
> PETSC_DIR: /home/scratch/yixun/petsc-3.0.0-p3
> ** Now build the libraries with "make all"
> Clanguage: C
> PETSc shared libraries: disabled
> PETSc dynamic libraries: disabled
> Scalar type:real
> MPI:
> Includes: -I/usr/lib64/mpi/gcc/openmpi/include
> -I/usr/lib64/mpi/gcc/openmpi/lib64
> X11:
> Includes: ['']
> Library: ['-lX11']
> BLAS/LAPACK: -llapack -lblas
> ParMetis:
> -I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
> Library:
> -Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
> -L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lparmetis
> -lmetis
> Yixun
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090804/0cf98d45/attachment.htm>
