make test errors
Yixun Liu enjoywm at cs.wm.edu
Tue Aug 4 15:51:52 CDT 2009
I encounter the error as I run make test,
>make test
Running test examples to verify correct installation
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
process
See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined symbol:
dat_registry_add_provider
I list the output of configure. Hope it helpful for diagnosis.
> ./config/configure.py --download-parmetis
TESTING: alternateConfigureLibrary from
PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:69)
Compilers:
  C Compiler:         mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -g3
  Fortran Compiler:   mpif90  -Wall -Wno-unused-variable -g
Linkers:
  Static linker:   /usr/bin/ar cr
PETSc:
  ** Before running "make" your PETSC_ARCH must be specified with:
  **  ** setenv PETSC_ARCH linux-gnu-c-debug (csh/tcsh)
  **  ** PETSC_ARCH=linux-gnu-c-debug; export PETSC_ARCH (sh/bash)
  PETSC_DIR: /home/scratch/yixun/petsc-3.0.0-p3
  ** Now build the libraries with "make all"
  Clanguage: C
  PETSc shared libraries: disabled
  PETSc dynamic libraries: disabled
  Scalar type:real
MPI:
  Includes: -I/usr/lib64/mpi/gcc/openmpi/include
-I/usr/lib64/mpi/gcc/openmpi/lib64
X11:
  Includes: ['']
  Library: ['-lX11']
BLAS/LAPACK: -llapack -lblas
ParMetis:
-I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
  Library:
-Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
-L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lparmetis
-lmetis
Yixun
