BAIJ and AIJ formats
Manav Bhatia
bhatiamanav at gmail.com
Sun Sep 28 14:50:41 CDT 2008
One more question:
When is it advantageous to use BAIJ format instead of AIJ?
Manav
On Sep 28, 2008, at 3:48 PM, Manav Bhatia wrote:
> Hi,
> I have a few questions about the block format matrix.
> In the function: MatCreateSeqBAIJ, the arguments are
> bs - size of block
> m - number of rows
> n - number of columns
> nz - number of nonzero blocks per block row (same for all rows)
> nnz - array containing the number of nonzero blocks in the various
> block rows (possibly different for each block row) or PETSC_NULL
> If I specify the nnz vector, then what is the dimension of this
> vector? Is that equal to the block size? If so, then is it assumed
> that all blocks have the same number of non-zeros per row?
> If my blocks have different non-zero patterns, then should I use an
> AIJ format instead of a BAIJ format?
> Thanks,
> Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080928/2f613e14/attachment.htm>
