BAIJ and AIJ formats
Hong Zhang
hzhang at mcs.anl.gov
Sun Sep 28 16:58:42 CDT 2008
Manav,
If your matrix can be stored as BAIJ
with dense blocks, then using BAIJ would be
more memory efficient.
See slides 42 of
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/tutorials/LCRC-06.pdf.
Hong
On Sun, 28 Sep 2008, Manav Bhatia wrote:
> One more question:
> When is it advantageous to use BAIJ format instead of AIJ?
> Thanks,
> Manav
> On Sep 28, 2008, at 3:48 PM, Manav Bhatia wrote:
>> Hi,
>> I have a few questions about the block format matrix.
>> In the function: MatCreateSeqBAIJ, the arguments are
>> bs - size of block
>> m - number of rows
>> n - number of columns
>> nz - number of nonzero blocks per block row (same for all rows)
>> nnz - array containing the number of nonzero blocks in the various block
>> rows (possibly different for each block row) or PETSC_NULL
>> If I specify the nnz vector, then what is the dimension of this vector? Is
>> that equal to the block size? If so, then is it assumed that all blocks
>> have the same number of non-zeros per row?
>> If my blocks have different non-zero patterns, then should I use an AIJ
>> format instead of a BAIJ format?
>> Thanks,
>> Manav
