inconsistent singular systems
    Matthew Knepley
    knepley at gmail.com
    Tue Sep 16 12:38:51 CDT 2008
On Tue, Sep 16, 2008 at 11:56 AM, zhifeng sheng <z.sheng at ewi.tudelft.nl> wrote:
> Hi,
> how is the nullspace be implemented in the solver? by using Lagrange
> multiplier?
You have to have an explicit basis for the null space in order for
PETSc to use it.
  Matt
> best regards
> Zhifeng
> Barry Smith wrote:
>> On Sep 16, 2008, at 10:10 AM, Håkan Jakobsson wrote:
>>> Hi,
>>> How does PETSc handle the solution of a singular system Ax=b which also
>>> happens to be inconsistent? More specifically: is b orthogonalized against
>>> Null(A) internally by PETSc?
>>  No, you are expected to do this before calling the solver on the right
>> hand side. Note: if A is not symmetric then I think you want to apply the
>> Null(A')
>>  MatNullSpaceCreate() and KSPSetNullSpace() are a way you can tell the
>> iterative solver the null space, otherwise most iterative solvers will
>> create a giant
>> solution in the null space direction and not converge.
>>   Barry
>>> Thanks
>>> Håkan Jakobsson
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
