inconsistent singular systems
zhifeng sheng z.sheng at ewi.tudelft.nl
Tue Sep 16 11:56:17 CDT 2008
how is the nullspace be implemented in the solver? by using Lagrange
multiplier?
best regards
Zhifeng
Barry Smith wrote:
> On Sep 16, 2008, at 10:10 AM, Håkan Jakobsson wrote:
>> Hi,
>> How does PETSc handle the solution of a singular system Ax=b which
>> also happens to be inconsistent? More specifically: is b
>> orthogonalized against Null(A) internally by PETSc?
>   No, you are expected to do this before calling the solver on the
> right hand side. Note: if A is not symmetric then I think you want to
> apply the Null(A')
>   MatNullSpaceCreate() and KSPSetNullSpace() are a way you can tell
> the iterative solver the null space, otherwise most iterative solvers
> will create a giant
> solution in the null space direction and not converge.
>    Barry
>> Thanks
>> Håkan Jakobsson
