inconsistent singular systems
    Håkan Jakobsson
    hakan.jakobsson at math.umu.se
    Tue Sep 16 12:48:31 CDT 2008
Thanks for the quick response. I've tried both orthogonalizing and
not, having convergence in both cases and very similar solutions.
Likely since b has been almost orthogonal to Null(A) already.
/Håkan
On Sep 16, 2008, at 6:35 PM, Barry Smith wrote:
> On Sep 16, 2008, at 10:10 AM, Håkan Jakobsson wrote:
>> Hi,
>> How does PETSc handle the solution of a singular system Ax=b which
>> also happens to be inconsistent? More specifically: is b
>> orthogonalized against Null(A) internally by PETSc?
>   No, you are expected to do this before calling the solver on the
> right hand side. Note: if A is not symmetric then I think you want
> to apply the Null(A')
>   MatNullSpaceCreate() and KSPSetNullSpace() are a way you can tell
> the iterative solver the null space, otherwise most iterative
> solvers will create a giant
> solution in the null space direction and not converge.
>    Barry
>> Thanks
>> Håkan Jakobsson
