symmetric reordering and incomplete factorization with tolerance?
Tue Sep 16 11:43:12 CDT 2008
   If you run with -ksp_view it calls PCView_ICC internally, or you
can call PCView(). You never call PCView_ICC() directly.
    Barry
On Sep 16, 2008, at 11:32 AM, zhifeng sheng wrote:
> Hi Barry
> Where can I find and use PCView_ICC ?
> thanks
> Zhifeng
> Barry Smith wrote:
>> On Sep 16, 2008, at 10:57 AM, zhifeng sheng wrote:
>>> Dear Barry
>>> I tried the RCM+ICC(2) in Petsc.... it seems that the reordering
>>> does not work well... as I view the preconditioner, it does not
>>> say in which way the matrix is reordered.
>>   I've added this information to PCView_ICC.
>>> And when I solve it with KSP, the solver always complains about
>>> Detected zero pivot in Cholesky factorization
>>> How could it be?
>>    This is very possible, there is nothing that says you take some
>> symmetric matrix and do an ICC on it that you will get a positive
>> definite matrix or
>> no zero pivots.
>>   You can use -pc_factor_shift_positive_definite to force the ICC
>> to generate a positive definite matrix.
>>   Barry
>>> Thanks
>>> Best regards
>>> Zhifeng
>>> Barry Smith wrote:
>>>>  You should use rcm+icc if you want to keep a symmetric
>>>> preconditioner.
>>>>  Depending on your matrix you might want to use KSPCR or
>>>> KSPMINRES or even KSPSYMMLQ
>>>> instead of bicgstab?
>>>>  We don't have a drop tolerance ICC and I do not recommend our
>>>> drop tolerance ILU.
>>>>  Barry
>>>> On Sep 16, 2008, at 10:23 AM, zhifeng sheng wrote:
>>>>> Dear all
>>>>> I used the reordering scheme in petsc, and I would like to know
>>>>> whether they are symmetric or not.
>>>>> I have a symmetric matrix (for 3D system) and I tried to solve
>>>>> it with petsc and with matlab.
>>>>> In petsc I used rcm + ILU + bicgstab. while in matlab I used
>>>>> symrcm+ICC+bicgstab.
>>>>> it seems that with symmetric reordering, the factorization is
>>>>> somewhat faster... So I am wondering if it is possible to apply
>>>>> a symmetric reordering?
>>>>> PS: in Matlab, an incomplete factorization can be done with a
>>>>> tolerance (e.g. ICC(1e-4) ), can I do something like that with
>>>>> Petsc?
>>>>> Thanks a lot
>>>>> Best regards
>>>>> Zhifeng Sheng
