symmetric reordering and incomplete factorization with tolerance?
zhifeng sheng
z.sheng at ewi.tudelft.nl
Tue Sep 16 11:32:33 CDT 2008
Hi Barry
Where can I find and use PCView_ICC ?
thanks
Zhifeng
Barry Smith wrote:
> On Sep 16, 2008, at 10:57 AM, zhifeng sheng wrote:
>> Dear Barry
>> I tried the RCM+ICC(2) in Petsc.... it seems that the reordering does
>> not work well... as I view the preconditioner, it does not say in
>> which way the matrix is reordered.
> I've added this information to PCView_ICC.
>> And when I solve it with KSP, the solver always complains about
>> Detected zero pivot in Cholesky factorization
>> How could it be?
> This is very possible, there is nothing that says you take some
> symmetric matrix and do an ICC on it that you will get a positive
> definite matrix or
> no zero pivots.
> You can use -pc_factor_shift_positive_definite to force the ICC to
> generate a positive definite matrix.
> Barry
>> Thanks
>> Best regards
>> Zhifeng
>> Barry Smith wrote:
>>> You should use rcm+icc if you want to keep a symmetric
>>> preconditioner.
>>> Depending on your matrix you might want to use KSPCR or KSPMINRES
>>> or even KSPSYMMLQ
>>> instead of bicgstab?
>>> We don't have a drop tolerance ICC and I do not recommend our drop
>>> tolerance ILU.
>>> Barry
>>> On Sep 16, 2008, at 10:23 AM, zhifeng sheng wrote:
>>>> Dear all
>>>> I used the reordering scheme in petsc, and I would like to know
>>>> whether they are symmetric or not.
>>>> I have a symmetric matrix (for 3D system) and I tried to solve it
>>>> with petsc and with matlab.
>>>> In petsc I used rcm + ILU + bicgstab. while in matlab I used
>>>> symrcm+ICC+bicgstab.
>>>> it seems that with symmetric reordering, the factorization is
>>>> somewhat faster... So I am wondering if it is possible to apply a
>>>> symmetric reordering?
>>>> PS: in Matlab, an incomplete factorization can be done with a
>>>> tolerance (e.g. ICC(1e-4) ), can I do something like that with Petsc?
>>>> Thanks a lot
>>>> Best regards
>>>> Zhifeng Sheng
