OpenFVM
Shengyong
lua.byhh at gmail.com
Thu Sep 18 00:07:50 CDT 2008
Hi Haudin,
I have viewed the source and found no PETSc implementation.
Pang
On Tue, Sep 16, 2008 at 8:26 PM, Jean-Marc Haudin <xmailerpro at gmx.net>wrote:
> OpenFVM is a general CFD solver released under the GPL license. It was
> developed to simulate the flow in complex 3D geometries.
> Therefore, the mesh can be unstructured and contain control volumes with
> arbritrary shape. The code uses the finite volume method to
> evaluate the partial differential equations. As well as solving the
> velocity and pressure fields, the code is capable of solving
> non-isothermal multiphase flow.
> The code has two implementations: serial and parallel. The serial version
> uses LASPACK as the linear matrix solver and the parallel one
> uses the PETSc library. Both implementations use the open source tool Gmsh
> for pre- and -post processing.
> http://openfvm.sourceforge.net/
> Gesendet mit X-Mailer .... http://sourceforge.net/projects/x-mailer/
Pang Shengyong
Solidification Simulation Lab,
State Key Lab of Mould & Die Technology,
Huazhong Univ. of Sci. & Tech. China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080918/d269f0a2/attachment.htm>
