how to get all the singular values of the matrix?
Mon Jan 14 00:06:19 CST 2008
You can use
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPComputeEigenvaluesExplicitly.html
with and without a preconditioner. We have not coded the SVD
counterpart, but you can use
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPComputeExplicitOperator.html
and then call the LAPACK yourself.
  Matt
On Jan 13, 2008 11:23 PM, Yujie <recrusader at gmail.com> wrote:
> Hi, everyone
> I want to select iterative methods by observing the singular values
> decompostion of the matrix. However, I don't know how to get all the
> singular values of the matrix in PETSc. I know the command
> "-ksp_monitor_singular_value" may get the max and min singular values at
> each iteration. How to get the singular values of the matrix I want to
> solve? In addition, when I use the preconditioned iterative method, how to
> get the singular values of the preconditioned iterative operator?
> thanks a lot.
> Regards,
> Yujie
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
