how to get all the singular values of the matrix?
Yujie
recrusader at gmail.com
Mon Jan 14 00:14:54 CST 2008
Thank you for your advice.
I have used -ksp_compute_eigenvalues_explicitly to get the eigen values.
However, it is very very
slow because the dimension of the matrix is about ten thousand.
Yujie
On 1/14/08, Matthew Knepley <knepley at gmail.com> wrote:
> You can use
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPComputeEigenvaluesExplicitly.html
> with and without a preconditioner. We have not coded the SVD
> counterpart, but you can use
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPComputeExplicitOperator.html
> and then call the LAPACK yourself.
> Matt
> On Jan 13, 2008 11:23 PM, Yujie <recrusader at gmail.com> wrote:
> > Hi, everyone
> > I want to select iterative methods by observing the singular values
> > decompostion of the matrix. However, I don't know how to get all the
> > singular values of the matrix in PETSc. I know the command
> > "-ksp_monitor_singular_value" may get the max and min singular values at
> > each iteration. How to get the singular values of the matrix I want to
> > solve? In addition, when I use the preconditioned iterative method, how
> to
> > get the singular values of the preconditioned iterative operator?
> > thanks a lot.
> > Regards,
> > Yujie
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080114/1eb733be/attachment.htm>
