Weird (?) results obtained from experiments with the SNESMF module
    Matthew Knepley
    knepley at gmail.com
    Fri Dec 19 16:53:30 CST 2008
On Fri, Dec 19, 2008 at 4:39 PM, Rafael Santos Coelho <
rafaelsantoscoelho at gmail.com> wrote:
> Hey, Barry,
> here's what you asked:
You are taking 25K + iterations of GMRES(30).  This I think is probably
pretty sensitive to the
exact nature of the FD approximation. Did you try varying the h parameter?
  Matt
> JFNK
> KSP SOLVER: GMRES
> MESH SIZE : 512 x 512 unknows
> NUMBER OF PROCESSORS : 24
> Linear solve converged due to CONVERGED_RTOL iterations 25042
> Linear solve converged due to CONVERGED_RTOL iterations 33804
> Linear solve converged due to CONVERGED_RTOL iterations 33047
> Linear solve converged due to CONVERGED_RTOL iterations 21219
> SNES Object:
>   type: ls
>     line search variant: SNESLineSearchCubic
>     alpha=0.0001, maxstep=1e+08, steptol=1e-12
>   maximum iterations=100, maximum function evaluations=1000000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=113112
>   total number of function evaluations=116893
>   KSP Object:
>     type: gmres
>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>       GMRES: happy breakdown tolerance 1e-30
>     maximum iterations=1000000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>     left preconditioning
>   PC Object:
>     type: none
>     linear system matrix = precond matrix:
>     Matrix Object:
>       type=mffd, rows=262144, cols=262144
>           matrix-free approximation:
>             err=1e-07 (relative error in function evaluation)
>             Using wp compute h routine
>             Computes normA
>             Does not compute normU
> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
>                                          Max           Max/Min
> Avg             Total
> Time (sec):                    8.080e+02      1.00009     8.080e+02
> Objects:                        6.600e+01      1.00000     6.600e+01
> Flops:                           1.044e+11      1.01176     1.036e+11
> 2.485e+12
> Flops/sec:                     1.292e+08      1.01184     1.282e+08
> 3.076e+09
> Memory:                       5.076e+06      1.01530
> 1.207e+08
> MPI Messages:             4.676e+05      2.00000     3.702e+05    8.884e+06
> MPI Message Lengths:  4.002e+08      2.00939     8.623e+02    7.661e+09
> MPI Reductions:            9.901e+03      1.00000
> Object Type          Creations   Destructions   Memory  Descendants' Mem.
> --- Event Stage 0: Main Stage
> SNES                        1              1                 124
> 0
> Krylov Solver              1              1                16880          0
> Preconditioner            1              1                   0
> 0
> Distributed array         1              1               46568           0
> Index Set                   6              6               135976         0
> Vec                          46             46            3901252         0
> Vec Scatter                3              3
> 0               0
> IS L to G Mapping       1              1              45092            0
> MatMFFD                   1              1                  0
> 0
> Matrix                        4              4              1011036
> 0
> Viewer                       1              1
> 0              0
> OptionTable: -ksp_converged_reason
> OptionTable: -ksp_max_it 1000000
> OptionTable: -ksp_type gmres
> OptionTable: -log_summary
> OptionTable: -option_table
> OptionTable: -par 4.0
> OptionTable: -pc_type none
> OptionTable: -snes_converged_reason
> OptionTable: -snes_max_funcs 1000000
> OptionTable: -snes_max_it 100
> OptionTable: -snes_mf
> OptionTable: -snes_view
> OptionTable: -xdiv 512
> OptionTable: -ydiv 512
> NK
> KSP SOLVER: GMRES
> Linear solve converged due to CONVERGED_RTOL iterations 25038
> Linear solve converged due to CONVERGED_RTOL iterations 25995
> Linear solve converged due to CONVERGED_RTOL iterations 26769
> SNES Object:
>   type: ls
>   total number of linear solver iterations=77802
>   total number of function evaluations=4
>   KSP Object:
>     type: gmres
>   PC Object:
>     type: none
>     Matrix Object:
>       type=mpiaij, rows=262144, cols=262144
>       total: nonzeros=1308672, allocated nonzeros=1308672
>         not using I-node (on process 0) routines
>                                          Max          Max/Min
> Avg           Total
> Time (sec):                   5.329e+02      1.00008   5.329e+02
> Objects:                       6.300e+01      1.00000   6.300e+01
> Flops:                          6.553e+10      1.01230   6.501e+10
> 1.560e+12
> Flops/sec:                    1.230e+08      1.01230   1.220e+08
> 2.928e+09
> Memory:                       4.989e+06      1.01589
> 1.186e+08
> MPI Messages:             3.216e+05      1.99999   2.546e+05    6.111e+06
> MPI Message Lengths:  2.753e+08      2.00939   8.623e+02    5.269e+09
> MPI Reductions:           6.704e+03      1.00000
> SNES                        1              1
> 124                 0
> 0
> Preconditioner             1              1
> 0                   0
> 0
> 0
> Vec                           45             45         3812684
> 0
> Vec Scatter                3              3
> 0                   0
> Matrix                        3              3
> 1011036              0
> Viewer                       1              1
> 0                   0
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081219/9ae27015/attachment.htm>
