Weird (?) results obtained from experiments with the SNESMF module
Rafael Santos Coelho rafaelsantoscoelho at gmail.com
Fri Dec 19 16:39:19 CST 2008
Hey, Barry,
here's what you asked:
JFNK
KSP SOLVER: GMRES
MESH SIZE : 512 x 512 unknows
NUMBER OF PROCESSORS : 24
Linear solve converged due to CONVERGED_RTOL iterations 25042
Linear solve converged due to CONVERGED_RTOL iterations 33804
Linear solve converged due to CONVERGED_RTOL iterations 33047
Linear solve converged due to CONVERGED_RTOL iterations 21219
SNES Object:
  type: ls
    line search variant: SNESLineSearchCubic
    alpha=0.0001, maxstep=1e+08, steptol=1e-12
  maximum iterations=100, maximum function evaluations=1000000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=113112
  total number of function evaluations=116893
  KSP Object:
    type: gmres
      GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=1000000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    left preconditioning
  PC Object:
    type: none
    linear system matrix = precond matrix:
    Matrix Object:
      type=mffd, rows=262144, cols=262144
          matrix-free approximation:
            err=1e-07 (relative error in function evaluation)
            Using wp compute h routine
            Computes normA
            Does not compute normU
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
                                         Max           Max/Min
Avg             Total
Time (sec):                    8.080e+02      1.00009     8.080e+02
Objects:                        6.600e+01      1.00000     6.600e+01
Flops:                           1.044e+11      1.01176     1.036e+11
2.485e+12
Flops/sec:                     1.292e+08      1.01184     1.282e+08
3.076e+09
Memory:                       5.076e+06      1.01530
1.207e+08
MPI Messages:             4.676e+05      2.00000     3.702e+05    8.884e+06
MPI Message Lengths:  4.002e+08      2.00939     8.623e+02    7.661e+09
MPI Reductions:            9.901e+03      1.00000
Object Type          Creations   Destructions   Memory  Descendants' Mem.
--- Event Stage 0: Main Stage
SNES                        1              1                 124
0
Krylov Solver              1              1                16880          0
Preconditioner            1              1                   0
0
Distributed array         1              1               46568           0
Index Set                   6              6               135976         0
Vec                          46             46            3901252         0
Vec Scatter                3              3                  0
0
IS L to G Mapping       1              1              45092            0
MatMFFD                   1              1                  0              0
Matrix                        4              4              1011036        0
Viewer                       1              1
0              0
OptionTable: -ksp_converged_reason
OptionTable: -ksp_max_it 1000000
OptionTable: -ksp_type gmres
OptionTable: -log_summary
OptionTable: -option_table
OptionTable: -par 4.0
OptionTable: -pc_type none
OptionTable: -snes_converged_reason
OptionTable: -snes_max_funcs 1000000
OptionTable: -snes_max_it 100
OptionTable: -snes_mf
OptionTable: -snes_view
OptionTable: -xdiv 512
OptionTable: -ydiv 512
NK
KSP SOLVER: GMRES
Linear solve converged due to CONVERGED_RTOL iterations 25038
Linear solve converged due to CONVERGED_RTOL iterations 25995
Linear solve converged due to CONVERGED_RTOL iterations 26769
SNES Object:
  type: ls
  total number of linear solver iterations=77802
  total number of function evaluations=4
  KSP Object:
    type: gmres
  PC Object:
    type: none
    Matrix Object:
      type=mpiaij, rows=262144, cols=262144
      total: nonzeros=1308672, allocated nonzeros=1308672
        not using I-node (on process 0) routines
                                         Max          Max/Min
Avg           Total
Time (sec):                   5.329e+02      1.00008   5.329e+02
Objects:                       6.300e+01      1.00000   6.300e+01
Flops:                          6.553e+10      1.01230   6.501e+10
1.560e+12
Flops/sec:                    1.230e+08      1.01230   1.220e+08
2.928e+09
Memory:                       4.989e+06      1.01589
1.186e+08
MPI Messages:             3.216e+05      1.99999   2.546e+05    6.111e+06
MPI Message Lengths:  2.753e+08      2.00939   8.623e+02    5.269e+09
MPI Reductions:           6.704e+03      1.00000
SNES                        1              1
124                 0
0
Preconditioner             1              1
0                   0
0
Vec                           45             45         3812684
0
Vec Scatter                3              3
0                   0
Matrix                        3              3
1011036              0
Viewer                       1              1
0                   0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081219/8426995a/attachment.htm>
