How to set '_pc_factor_shift_postive_define' not in runtime?
Matthew Knepley
knepley at gmail.com
Sat Aug 16 06:47:49 CDT 2008
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCFactorSetShiftPd.html
Matt
On Sat, Aug 16, 2008 at 4:38 AM, Shengyong <lua.byhh at gmail.com> wrote:
> Hi,
> I am going to solve a variable coefficient Poisson equation with ICCG
> method, ie, the pc-type is icc while the ksp type is pcg. I have found
> functions in petsc library for setting such options. But how to set this
> type of options for PC object, for instance ,'
> _pc_factor_shift_positive_define' not in runtime? Which functions should I
> call if I want to set this type of option previous in an exectuable
> program. Because It is not so convient for me to use runtime options on
> Windows.
> Best Regards,
> Pang Shengyong
> Solidification Simulation Lab,
> State Key Lab of Mould & Die Technology,
> Huazhong Univ. of Sci. & Tech. China
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
