How to set '_pc_factor_shift_postive_define' not in runtime?
Shengyong lua.byhh at gmail.com
Sat Aug 16 04:38:14 CDT 2008
I am going to solve a variable coefficient Poisson equation with ICCG
method, ie, the pc-type is icc while the ksp type is pcg.  I have found
functions in petsc library for setting such options.  But how to set this
type of options for PC object,  for instance ,'
_pc_factor_shift_positive_define' not in runtime?  Which functions should I
call if I want to set this type of option previous in an exectuable
program.  Because It is not so convient for me to use runtime options on
Windows.
Best Regards,
Pang Shengyong
Solidification Simulation Lab,
State Key Lab of Mould & Die Technology,
Huazhong Univ. of Sci. & Tech. China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080816/6a5f3e11/attachment.htm>
