How to set '_pc_factor_shift_postive_define' not in runtime?
Shengyong
lua.byhh at gmail.com
Sat Aug 16 07:20:06 CDT 2008
Hi, Matt
Thank you very much.
On Sat, Aug 16, 2008 at 7:47 PM, Matthew Knepley <knepley at gmail.com> wrote:
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCFactorSetShiftPd.html
> Matt
> On Sat, Aug 16, 2008 at 4:38 AM, Shengyong <lua.byhh at gmail.com> wrote:
> > Hi,
> > I am going to solve a variable coefficient Poisson equation with ICCG
> > method, ie, the pc-type is icc while the ksp type is pcg. I have found
> > functions in petsc library for setting such options. But how to set this
> > type of options for PC object, for instance ,'
> > _pc_factor_shift_positive_define' not in runtime? Which functions should
> I
> > call if I want to set this type of option previous in an exectuable
> > program. Because It is not so convient for me to use runtime options on
> > Windows.
> > Best Regards,
> > Pang Shengyong
> > Solidification Simulation Lab,
> > State Key Lab of Mould & Die Technology,
> > Huazhong Univ. of Sci. & Tech. China
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080816/3348b221/attachment.htm>
