Petsc questions
Nguyen, Hung V ERDC-ITL-MS
Hung.V.Nguyen at usace.army.mil
Fri Aug 15 08:04:23 CDT 2008
Barry,
Thank you all,
-Hung
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On
Behalf Of Barry Smith
Sent: Thursday, August 14, 2008 8:50 PM
To: petsc-users at mcs.anl.gov
Subject: Re: Petsc questions
On Aug 14, 2008, at 1:33 PM, Matthew Knepley wrote:
> On Thu, Aug 14, 2008 at 1:22 PM, Nguyen, Hung V ERDC-ITL-MS
> <Hung.V.Nguyen at usace.army.mil> wrote:
>> Barry,
>> Thanks for the info. I will use what we already have. How's about
>> estimation of matrix condition number via PETSC?
> You can use -ksp_monitor_singular_value to print out the exterior
> singular values for the Hessenberg matrix generated by the Krylov
> method. I don't think we have anything else. Condition number
> estimation is a tough problem.
See also KSPSetComputeSingularValues(), KSPSetComputeEigenvalues(),
KSPComputeSingularValues(), KSPComputeEigenvalues() for use in your
code.
I've found if the operator is not terribly ill-conditioned these can
work fairly well.
If using GMRES for a non-symmetric matrix make sure you use a large
enough
restart to get accurate values.
Barry
> Matt
>> -Hung
>> ] On
>> Sent: Thursday, August 14, 2008 11:08 AM
>> Check AO functions. They renumber between two different orderings.
>> But, if your code already puts everything in the new numbering, you
>> can just
>> use PETSc with that new numbering and leave your ordering code as
>> it is.
>> Barry
>> On Aug 14, 2008, at 9:37 AM, Nguyen, Hung V ERDC-ITL-MS wrote:
>>> Hello All,
>>> I am new to PETSC. I have following questions about PETSC:
>>> 1. Do PETSC functions help to estimate/calculate a matrix condition
>>> number?
>>> If yes, can I get the info how to do it?
>>> 2. A question about renumbering nodes: our CFD code uses ParMetis to
>>> compute the original partitioning of the mesh. The global nodes are
>>> renumbered consecutively within each Parmetis partition as npetsc
>>> which is a mapping vector from the original global node numbering to
>>> the new numbering, see below as a test code. My question is whether
>>> PETSC function helps to renumber from ParMetis partition to PETSC
>>> partition or not?
>>> Thank for your help.
>>> Regards,
>>> -Hung
>>> -- code:
>>> ! Read the data.
>>> fname = 'petsc.dat'
>>> call parnam (fname)
>>> open (2, file = fname, status = 'old')
>>> ! No. global nodes, local nodes, owned nodes,
>>> ! compressed columns, PEs.
>>> read (2, '(5i10)') ng, nloc, nown, ncol, npes
>>> if (noproc .ne. npes) then
>>> if (myid .eq. 0) then
>>> print*, 'Number of PEs from the data file does not match',
>>> & ' the number from the run command.'
>>> end if
>>> call PetscFinalize (ierr)
>>> stop
>>> end if
>>> ! Local node array containing global node numbers.
>>> allocate (nglobal(nloc))
>>> read (2, '(8i10)') nglobal
>>> ! Find petsc numbering scheme.
>>> allocate (nown_all(noproc))
>>> allocate (idisp(noproc))
>>> allocate (npetsc(nloc))
>>> allocate (nodes1(ng))
>>> allocate (nodes2(ng))
>>> call MPI_ALLGATHER (nown, 1, MPI_INTEGER, nown_all, 1,
>>> & MPI_INTEGER, PETSC_COMM_WORLD, ierr)
>>> idisp(1) = 0
>>> do i = 2, noproc
>>> idisp(i) = idisp(i - 1) + nown_all(i - 1)
>>> end do
>>> call MPI_ALLGATHERV (nglobal, nown, MPI_INTEGER, nodes1,
>>> & nown_all, idisp, MPI_INTEGER, PETSC_COMM_WORLD, ierr)
>>> do i = 1, ng
>>> ii = nodes1(i)
>>> nodes2(ii) = i
>>> end do
>>> ! Process the local nodes for their petsc numbers.
>>> do i = 1, nloc
>>> ii = nglobal(i)
>>> npetsc(i) = nodes2(ii)
>>> end do
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
