running out mpi communicators with Prometheus
Stephan Kramer stephan.kramer at imperial.ac.uk
Thu Aug 14 12:17:54 CDT 2008
Hello
When running with Prometheus in parallel we get the following error
after about 1000 solves:
 Fatal error in MPI_Comm_dup: Other MPI error, error stack:
 MPI_Comm_dup(176)..: MPI_Comm_dup(comm=0x84000002,
               new_comm=0x36901e8c) failed
 MPIR_Comm_copy(547): Too many communicators
So it's seems like a MPI_Comm_dup not matched by a MPI_Comm_free. Our
model does a number of solves per time step, and for each solve all
PETSc objects (ksp, mat, pc and vec) are created and destroyed again.
It's only when we switch to prometheus and in parallel (no problems with
prometheus in serial) that the error occurs. Does anyone have any
suggestions how to track down the problem, or seen a similar problem?
I'm fairly sure we're not missing any KSP/PC/Vec or MatDestroys.
Cheers
Stephan Kramer
