problem in compiling petsc for visual c++ 2005
berry lua.byhh at gmail.com
Wed Aug 13 02:09:20 CDT 2008
Hi, Farshid
Thanks for you suggestions. Can you tell me the surfix of your compiled
library is .a or .lib?
On Wed, Aug 13, 2008 at 2:44 PM, Farshid Mossaiby <mossaiby at yahoo.com>wrote:
> Hi,
> I have built Petsc a lot of times with VC++ 2008 Express edition and
> Cygwin. I used to run C:\Cygwin\Cygwin.bat, and had no problem.
> I just looked into the batch file, and it contains:
> @echo off
> C:
> chdir C:\Cygwin\bin
> bash --login -i
> I am not sure what '-i' in bash parameters mean, but it may help you.
> Anyway, I still recommend you running the batch file itself.
> Best regards,
> Farshid Mossaiby
> --- On Tue, 8/12/08, berry <lua.byhh at gmail.com> wrote:
> > From: berry <lua.byhh at gmail.com>
> > Subject: Re: problem in compiling petsc for visual c++ 2005
> > To: petsc-users at mcs.anl.gov
> > Date: Tuesday, August 12, 2008, 9:49 PM
> > Hi, Satish
> > Sorry for my vague reply.
> > I just use 'bash' not 'bash --login'. With
> > 'bash' only, the configure script
> > can not find 'mkdir' and 'sed' command, as
> > you kindly points me out.
> > Then I try this utilities: 'usr/bin/run.exe -ls'
> > to open a xterm window. I
> > Successed.  In this window, I can find 'mkdir' and
> > 'sed' plus visual c++'s
> > 'cl.exe' and intel fortran 's
> > 'ifort.exe' now.
> > After that, I do configure petsc again with
> > './config/configure.py '( I can
> > not remember other paramters for mpich , lapack, blas,
> > winfe cl , winfe
> > ifort and hypre now, but I follow the exact guidence from
> > petsc official
> > website).
> > However, after several minutes's configuration, petsc
> > configuration script
> > still CRASHED with no error prompt on screen. It just tell
> > me to send the
> > config.log file to developers. Right now I am not in my
> > office, tomorrow I
> > will send the config.log file to corresponding email
> > address.
> > Hope this time you can understand what I say.
> > Thanks for you help!
> > On Tue, Aug 12, 2008 at 10:43 PM, Satish Balay
> > <balay at mcs.anl.gov> wrote:
> > > On Tue, 12 Aug 2008, berry wrote:
> > > > Thanks,  I have already logged into the cygwin
> > from VC command prompt.
> > > What does this mean? do you now have mkdir and sed in
> > your path?
> > > If not - redo VC cmd prompt - and 'bash
> > --login' - and let us know if:
> > > - mkdir & sed are in your PATH
> > > which sed
> > > which mkdir
> > > - now configure is successful or not..
> > > Satish
> > Pang Shengyong
> > Solidification Simulation Lab,
> > State Key Lab of Mould & Die Technology,
> > Huazhong Univ. of Sci. & Tech. China
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080813/ef57cc41/attachment.htm>
