problem in compiling petsc for visual c++ 2005
Farshid Mossaiby mossaiby at yahoo.com
Wed Aug 13 03:06:17 CDT 2008
They are .lib files.
Best regards,
Farshid Mossaiby
--- On Wed, 8/13/08, berry <lua.byhh at gmail.com> wrote:
> From: berry <lua.byhh at gmail.com>
> Subject: Re: problem in compiling petsc for visual c++ 2005
> To: petsc-users at mcs.anl.gov
> Date: Wednesday, August 13, 2008, 11:39 AM
> Hi, Farshid
> Thanks for you suggestions. Can you tell me the surfix of
> your compiled
> library is .a or .lib?
> On Wed, Aug 13, 2008 at 2:44 PM, Farshid Mossaiby
> <mossaiby at yahoo.com>wrote:
> > Hi,
> > I have built Petsc a lot of times with VC++ 2008
> Express edition and
> > Cygwin. I used to run C:\Cygwin\Cygwin.bat,
> and had no problem.
> > I just looked into the batch file, and it contains:
> > @echo off
> > C:
> > chdir C:\Cygwin\bin
> > bash --login -i
> > I am not sure what '-i' in bash parameters
> mean, but it may help you.
> > Anyway, I still recommend you running the batch file
> itself.
> > Best regards,
> > Farshid Mossaiby
> > --- On Tue, 8/12/08, berry <lua.byhh at gmail.com>
> visual c++ 2005
> > > Date: Tuesday, August 12, 2008, 9:49 PM
> > > Hi, Satish
> > > Sorry for my vague reply.
> > > I just use 'bash' not 'bash
> --login'. With
> > > 'bash' only, the configure script
> > > can not find 'mkdir' and 'sed'
> command, as
> > > you kindly points me out.
> > > Then I try this utilities: 'usr/bin/run.exe
> -ls'
> > > to open a xterm window. I
> > > Successed.  In this window, I can find
> 'mkdir' and
> > > 'sed' plus visual c++'s
> > > 'cl.exe' and intel fortran 's
> > > 'ifort.exe' now.
> > > After that, I do configure petsc again with
> > > './config/configure.py '( I can
> > > not remember other paramters for mpich , lapack,
> blas,
> > > winfe cl , winfe
> > > ifort and hypre now, but I follow the exact
> guidence from
> > > petsc official
> > > website).
> > > However, after several minutes's
> configuration, petsc
> > > configuration script
> > > still CRASHED with no error prompt on screen. It
> just tell
> > > me to send the
> > > config.log file to developers. Right now I am not
> in my
> > > office, tomorrow I
> > > will send the config.log file to corresponding
> email
> > > address.
> > > Hope this time you can understand what I say.
> > > Thanks for you help!
> > > On Tue, Aug 12, 2008 at 10:43 PM, Satish Balay
> > > <balay at mcs.anl.gov> wrote:
> > > > On Tue, 12 Aug 2008, berry wrote:
> > > > > Thanks,  I have already logged into the
> cygwin
> > > from VC command prompt.
> > > > What does this mean? do you now have mkdir
> and sed in
> > > your path?
> > > > If not - redo VC cmd prompt - and 'bash
> > > --login' - and let us know if:
> > > > - mkdir & sed are in your PATH
> > > > which sed
> > > > which mkdir
> > > > - now configure is successful or not..
> > > > Satish
> > > Pang Shengyong
> > > Solidification Simulation Lab,
> > > State Key Lab of Mould & Die Technology,
> > > Huazhong Univ. of Sci. & Tech. China
> Pang Shengyong
