Establishing Fast Eth Beowulf Cluster for Using PETSc on that
Lisandro Dalcin dalcinl at gmail.com
Fri Nov 23 09:38:25 CST 2007
On 11/23/07, amjad ali <amjad11 at gmail.com> wrote:
> Now I want to setup a new Beowulf Cluster of few PCs to run PETSc
> program on that. please tell me steps of how to build it.
> I do not
> want to install MPICH2 separately on the cluster (just want to
> install/use as a part of PETSc).
I use a similar setup. I would recommed you to do the following:
* Make '/usr/local' availabe at your nodes using NFS.
* Build and install MPICH2 using prefix '/usr/local/mpich2'
$ ./configure --prefix=/usr/local/mpich2 ...
$ make
$ su -c 'make install' # or: sudo make install
* Now modify your path:
$ export PATH=/usr/local/mpich2/bin:$PATH
* Now build PETSc, unpacking sources on '/usr/local'
$ su -l
$ cd /usr/local
$ tar -zxf petsc-xxx.tar.gz
$ cd petsc-xxx
$ export PETSC_DIR=`pwd`
$ export PETSC_ARCH=linux-gnu
$ python config/configure.py <customization options>
$ make
And this should be all you have to do. You will have PETSc built at
'/usr/local/petsc-xxx', and all your nodes would be able to see and
use it via NFS.
If you have any problem, feel free to ask me again.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
