dropping columns/rows from matrix?
Peter Schröder ps at cs.caltech.edu
Fri Nov 23 18:58:33 CST 2007
As part of a greedy basis pursuit algorithm I drop/undrop columns/rows
from a matrix and resolve. I don't want to rebuild the matrix each time.
Is there a quick way to do this?
Basically the setup is this. Consider a 2-manifold triangle mesh and a
discretization (piecewise linear FE) of the Laplace-Beltrami operator
over this mesh (symmetric positive (semi-)definite [constant vector is
the only null space vector]). Fix boundary conditions (zero Dirichlet in
my case). Solve for a given rhs (I am using CG and absolute Jacobi as a
precon with good success). Based on the solution, take out a column (and
the same row) and resolve. Repeat this a few times until, say, 10
variables are dropped. Now pick one of them, say, i, and reintroduce it.
Based on the solution replace i with i_new. Now visit another variable
of the original 10 and "move" it. Etc.
Each one of the solves is quick (and I need to do hundreds for matrices
with hundreds of thousands to millions of variables). I'd rather not
rebuild the matrix each time... Any suggestions?
Thanks much!
Peter
