Banded Tridiagonal Matrices in PETSc
Tim Stitt timothy.stitt at ichec.ie
Thu Nov 22 12:55:54 CST 2007
Thanks Barry, that is all I need to know.
I can stick with my current implementation then...great stuff.
Barry Smith wrote:
>    There is a format Bdiag that stores by "banded diagonal". You will
> find that
> this performs slower than then the AIJ format.
>   If your matrix has constant values along the "diagaonals" then you
> will benefit from
> using a MatShell and writing custom code. if the values along the
> diagonals are
> not constant you will not do any better than AIJ anyways.
>    Barry
> On Nov 22, 2007, at 11:16 AM, Tim Stitt wrote:
>> Hi,
>> I was just wondering if PETSc has any special provision for banded
>> tridiagonal complex matrices when used in conjunction with
>> KSPSolve(). Are there any special PETSc matrix types or
>> factorisation/solver methods that benefit more from this matrix form?
>> Currently I am just using standard AIJ representation in my
>> serial/parallel codes.
>> I would be grateful for any thoughts.
>> Thanks,
>> Tim.
>> --Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>> HPC Application Consultant - ICHEC (www.ichec.ie)
>> Dublin Institute for Advanced Studies
>> 5 Merrion Square - Dublin 2 - Ireland
>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
